McFarlane Throttle cable replacement?
Dave C
Post by Dave C »
I have a McFarlane throttle in my plane and my mechanic trimmed the cables too short 2 years ago. This has resulted in great difficulty getting the carbs adjusted right since. Does anyone know if you can just replace the cables?
My plane is an Evektor Sportstar with a Rotax 912 ULS
-Dave
Re: McFarlane Throttle cable replacement?
It it is one like this, https://www.mcfarlaneaviation.com/produ ... V0005D048/, then probably not.
Dave C
Post by Dave C »
Yes, it looks like it might be the same thing just a bit longer. It is a MCTV0005D072
https://www.mcfarlaneaviation.com/produ ... V0005D072/
