Roadable aircraft flies!
I'll bet you won't see one of these in the showroom very soon. But, still quite an accomplishment! http://www.youtube.com/watch?v=EHXnLCIgNug
I'm guessing the canard was not as good as they hoped. The main gear is so far aft you would need 100 mph to rotate. The three surface should let it lift off in a fairly flat attitude but looks like that did not work. With every pitch control deflected it's a lot of drag.
One video I saw had some sound. It was pretty loud. Not sure what exhaust type.
But it flies and that's something. I'm sure they'll get the bugs worked out. Hopefully it's not something like the Moller Skycar project. This one looks a lot more promising.
They could have a far forward CG for testing also. If it was only ballasted forward then they should make some other flights very soon.
