Has anyone ever flown the Jabiru J230?
Posted: Thu May 10, 2018 1:49 pm
2009 Jabiru J230 Light Sport Aircraft...
https://www.sportpilottalk.com/
If you want cross country , go for the private certificate and get yourself some kind of RV ... no LSA plane will improve significantly on Ercoupe speed - yes, CTLS or Sting or Jabiru can give you 110 or so knots vs Ercoupe's 95 knots but that's not much of an improvement - RV will give you something along 140-150 knots.joey4420 wrote:Since this is an old post and I happen to be looking for a second aircraft. I will ask, How does the J230 fly? What would you compare it to? Any bad habits or traits? How does it handle grass strips? How is the Jabiru 3300 for Maintenance?
Before anyone asks, nope no intention of getting rid of my Ercoupe. Just looking for something more of a cross country bird.
I think your numbers are shy for the CTLS, and over optimistic for the Ercoupe. I think the speed delta will be just north of 40 mph. between the two.Warmi wrote:If you want cross country , go for the private certificate and get yourself some kind of RV ... no LSA plane will improve significantly on Ercoupe speed - yes, CTLS or Sting or Jabiru can give you 110 or so knots vs Ercoupe's 95 knots but that's not much of an improvement - RV will give you something along 140-150 knots.joey4420 wrote:Since this is an old post and I happen to be looking for a second aircraft. I will ask, How does the J230 fly? What would you compare it to? Any bad habits or traits? How does it handle grass strips? How is the Jabiru 3300 for Maintenance?
A little late to the party but to answer your question...sportflugzeug wrote:Thank you for responding.
I was flying a low wing Evektor and had to move to the high wing Jabiru. I like the space of the Jabiru and the Y stick. I feel it is easily controllable as I am right handed.
I found that steep turns (45 degree) were much easier in the Evektor. Also, power on stalls are more controllable in the Evektor.
I realize it is a different plane, but does high wing vs low wing make that big of a difference?
