zaitcev
Post by zaitcev »
Here's a video of a gyroplane with Rotax 912ULS taking off at a local field:
https://www.youtube.com/watch?v=1mNfoKhNSoY
It's not looking like them zooming at Sun-n-Fun, and that's with only 1 pilot onboard.
Flocker
Post by Flocker »
drseti wrote:When I did my most recent Rotax Heavy Maint renewal with Eric Tucker in January, we discussed both the 914 and the 912iS.
What are your thoughts on the 912is vs. 914 debate?
Aviation Real Estate Broker
There's no debate there. If you live in a mountainous area or consistently fly at or above 10,000 feet, the turbo is the way to go. For us flatlanders, it's unnecessary, and hard to justify the extra cost and maintenance expenses.
Flocker
Post by Flocker »
drseti wrote:For us flatlanders, it's unnecessary, and hard to justify the extra cost and maintenance expenses.
What is the (approx. ) difference in maintenance costs?
A friend of mine had a 914 powered Highlander. He sold it and bought a 912ULS powered airplane of the same type. He said the maintenance on the 914 engine was more complicated and expensive, and the extra power is only available for five minutes at a time, similar to the 5500-5800rpm band on the 912ULS. He said it was nice on takeoff, but just dead weight and extra expense at all other times.
The 915iS looks better because it makes continuous use of the turbo, or at least doesn't have a time limit on the extra horsies.
Mark Gregor
Post by Mark Gregor »
The 912ULS and the 912is are both fine and very adequate engines but the 914 is in a different league and it should be considering the cost.
I have heard this debated many times and its almost always by pilots who have no time behind a 914. I can sum it up quickly by saying that a very high percentage of buyers choose the 914 after flying the 912 and 914 back to back in the same airframe. If there was little difference they would not spend the extra money. There is a substantial difference. If anyone wants to see for themselves I would be happy to give a test flight in the same airframe with the different engines. Just come to Minnesota anytime and we will go for a ride!
From a sales standpoint it makes no difference to us which engine you choose. Its just that the 914 is a lot nicer to fly behind.
Mark Gregor
Tecnam US Inc.
507-327-9465
Flocker
Post by Flocker »
MrMorden wrote:A friend of mine had a 914 powered Highlander.... He said the maintenance on the 914 engine was more complicated and expensive...
Hundreds or thousands more expensive?
I was in Duluth for the announcement of the Tornado Alley Turbo-Normalized SR22.
Seemed like almost a free lunch - engine never stressed more than a normally aspirated one, just power held up to a much higher altitude with accompanying efficiency and TAS.
It only took a few years for owners to start seeing definite costs involved, with all sorts of failures of the installation, both large and small. Even sans failures, even routine maintenance and inspection was more time consuming and hence, more expensive.
If I had to WAG, I'd say maybe a 20% increase in maintenance costs. And very possibly still worth it to owners.
May or may not apply to the boosted ROTAX. But the saying about no free lunch does come to mind.
Still, like in the case of the Cirrus, it might still be worth it.
I can't give you any hard and fast numbers, since I don't maintain any 914s, but just in terms of the annual inspection, the Turbo will add about 2 to 3 hours of labor (that's a 20 to 30% increase). Roger Lee can probably speak to his experience.
SportPilot
Post by SportPilot »
Mark Gregor
The Rotax 914 turbocharged really should not be compared to a Lycoming or continental turbo normalized engine.
The 914 was designed for turbocharging from the beginning and has had many years to work out any bugs.
The design of the Rotax aircraft engine is also nearly 50 years newer. The engineering power Rotax has available is not really comparable. If Rotax decides they want to own the high horsepower piston aircraft market they could pretty much do it at any time. When you look at the total number of engines manufactured by Rotax and the many new designs they come out with every single year you will see that they can do pretty much what they want.
Tecnam tells us that when there is negativity toward the 914 it usually originates from a home built or one off installation. They tell us that although there are more moving parts they have not seen measurably less reliability from the 914 when compared to the 912. We have clearly seen more issues from the 912Is but after the updates it seems to be a good engine also.
Tecnam is the largest user of Rotax aircraft engines so they should know.
Mark
As far as additional maintenance costs of the 914 it is going to be more just because it has n more moving parts but based on our experience so far and what Tecnam is telling us I don't think it is a big issue.
jetcat3
Post by jetcat3 »
Hey y’all,
I’ve been pretty excited about this engine since it was announced two and a half years ago. It’s nice to see Rotax finally receive their type certificate for the engine! I thought this was particularly interesting. “Not only has the certification been achieved within the promised time schedule but the engine has been certified to even higher power than originally announced. Instead of 100kW (136hp) maximum power the engine will offer 104kW (141hp) maximum power instead and 99kW (135hp) maximum continuous power. Once more we will provide the ultimate flight experience to pilots.”
All 141 HP is available up to 15,000ft. Very impressive!
Another interesting thing I found was in the operators manual. They have the compression ratio listed as 8.2:1 for the 915 iS, whereas the 914 turbo is 9.0:1. The 912 ULS is 10.8:1. Any idea if that lower compression ratio will make the engine smoother? I have quite a bit of time behind the 914 turbo and 912 ULS and can say that the 914 is noticeably smoother but am not sure what all to contribute that to. Turbo, compression ratio, or a nice mixture of both? Thanks y’all.
I was interested in 915is as well but ....look at the price: https://www.cps-parts.com/catalog/rtxpa ... ine140.php
Damn. That is more than twice as expensive as 912 ULS - combine that with +50 lbs penalty ... I don't know.
CharlieTango
Post by CharlieTango »
Rotax has entered the flight levels
CharlieTango wrote:Rotax has entered the flight levels
Yeah . . . the price is out of this world.
Perhaps fitting for a new RANS S-21. But for that much money, you could probably install a 180hp Titan 340 . . . an awesome engine (standard equipment in the Carbon Cub!).
