Tower Endorsement
WDD
Re: Tower Endorsement
Post by WDD »
Things seem complicated.
They have no provision for a student pilot to get a student endorsement to fly a plane faster than 87kts. It appears they have two types of B, C, D endorsements - one for a student that is for a specific airport and good for only 90 days, and one for a licensed sport pilot good for any B, C, D and doesn't expire.
From the FAA website:
https://www.faa.gov/licenses_certificat ... idance.pdf
Student Pilot- Seeking a Sport Pilot Certificate - Endorsements
10. Solo flight to, from, or at an airport located in Class B, C, or D airspace or on an airport having
an operational control tower: §§ 61.94(a) and 91.131(b)(1) (required each additional 90-day period)
I certify that (First name, MI, Last name) has received the required training of § 61.94 (a) (1). I have
determined that he/she is proficient to conduct solo flight operations at (name of airport) located in Class B,
C, or D airspace or on an airport having an operational control tower. (List any applicable conditions or
limitations.) J. J. Jones, 12-25-2004 J. J. Jones 610610CFI 12-06
Sport Pilot Endorsements for
6. Class B, C, Or D Airspace, At An Airport Located In Class B, C, Or D Airspace, Or To, From,
Through, Or On An Airport Having An Operational Control Tower: §61.325
I certify that (First name, MI, Last name) has received the required training of § 61.325. I have determined
he/she is proficient to conduct operations in Class (B, C, or D) airspace, at an airport located in Class (B, C,
or D) airspace, or to, from, through, or on an airport having an operational control tower.
7. Light-Sport Aircraft That Has A VH Greater Than 87 Knots CAS: § 61.327(b)
I certify that (First name, MI, Last name) has received the required training of § 61.327 in a (make and
model aircraft). I have determined him/her proficient to act as PIC of a light-sport aircraft that has a VH
greater than 87 knots CAS.
Don't forget that there is a companion to the Vh > 87 kts endorsement, allowing a student pilot or sport pilot to solo an aircraft with a Vh < 87 kts. One must have (at least) one or the other. Are we confused yet?
WDD
Post by WDD »
And then, this from Paul Hamilton's web site:
http://sportpilottraining.sportaviation ... orsements/
Which looks a bit different. If I understand "or endorsements before checkride are applicable after checkride" language for Sport Pilot license owners, he might be saying you can get the permanent BCD airspace BEFORE the checkride????
Summary of “student pilot” solo logbook endorsements
(add any additional limitations as required for solo flights):
_____ Instructor endorses back of Student Pilot Certificate make/model § 61.87(n) (1).
Prior to first local supervised solo flight, place in logbook:
Speed endorsement required per § 61.89 (c) (5)(not required for WSC trikes and PPC under the 87 knots Vh)
I certify that (First name, MI, Last name) has received the required training of § 61.327 in a (make and model aircraft). I have determined him/her proficient to act as PIC of a light-sport aircraft that has a VH (greater or less) than 87 knots CAS. J. J. Jones, 12-25-2004 J. J. Jones 610610CFI 12-06
If towered airspace flights is required:
Solo flight in Class B, C, and D airspace, § 61.94(a) :
I certify that (First name, MI, Last name) has received the required training of § 61.94 (a). I have determined he/she is proficient to conduct solo flights in (name of Class B, C, or D) airspace. (List any applicable conditions or limitations.)
Additional Sport Pilot Endorsements after checkride (or endorsements before checkride are applicable after checkride)
Class B, C, Or D Airspace, At An Airport Located In Class B, C, Or D Airspace, Or To, From, Through, Or On An Airport Having An Operational Control Tower: § 61.325 (if applicable):
I certify that (First name, MI, Last name) has received the required training of § 61.325. I have determined he/she is proficient to conduct operations in Class B, C, or D* airspace, at an airport located in Class B, C, or D* airspace, or to, from, through, or on an airport having an operational control tower.
WDD
Post by WDD »
drseti wrote:Don't forget that there is a companion to the Vh > 87 kts endorsement, allowing a student pilot or sport pilot to solo an aircraft with a Vh < 87 kts. One must have (at least) one or the other. Are we confused yet?
Not a problem. Just fly something that ONLY goes 87 kts. Not anything faster or slower...... :D
WDD wrote:Things seem complicated.
61.89 (c), (5) is the requirement for having the speed endorsement. 61.327 (a) and (b) covers the endorsement. The instructor makes the endorsement for which ever speed of aircraft you are flying.
You are correct on the airspace endorsement. The same training for both, only the student pilot training must be in the specific airspace which they will be flying. Personally I see no reason that an instructor couldn't sign off for both when the instruction is given.
Interesting. I got my D class endorsement before my solo since I was training at KARR ( d class) but I never got the 87+ knots one despite flying Remos planes.
WDD
Post by WDD »
Warmi wrote:Interesting. I got my D class endorsement before my solo since I was training at KARR ( d class) but I never got the 87+ knots one despite flying Remos planes.
So does that mean you don't currently have an endorsement to go faster than 87 kts?
Can’t find one. I see B,C,D or on an airport having an operational tower and few others but not the 87 knots one.
WDD wrote: So does that mean you don't currently have an endorsement to go faster than 87 kts?
A common misconception. The endorsement has nothing whatever to do with the speed you fly. It refers to the capability of the aircraft you fly.
I got the endorsement for flying the sting ( as in the airplane model ) but it doesn’t reference explicitly 87 or frankly any other speed ....
See FAR 61.327. Point it out to your CFI - many haven't read it!
I am curious as to the background behind having this endorsement on the books in the first place... is this related to ultralights ?
Warmi wrote: is this related to ultralights ?
That was it's origin. In 2004 -2005, many fat ultralights were converted to ELSA (that window of opportunity has closed), and many Part 103 pilots then got SP ratings. The planes they had been flying were low-speed, high-drag, but soon those newly minted Sport Pilots stepped up to high-speed, low-drag LSAs, which they could legally do with no additional training. But, the flying characteristics of the two differ widely, and upgrading ultralight pilots began getting into trouble. So, FAA added the endorsements to ensure that some upgrade training be provided.
Warmi wrote:Can’t find one. I see B,C,D or on an airport having an operational tower and few others but not the 87 knots one.
Get that endorsement now. Legally speaking all of your solo flight without the endorsement was in violation of the regulations. There have been people sent home from their checkrides because of not having the endorsement.
Will do. I think people just don’t know about it cause nobody ever mentioned it to me except on this site.
