I have a tail dragger that I hand prop. I am looking to build some sort of tail wheel tie down that I can release from the cockpit. I don't want to use a glider tow hook release because they are expensive and look a little heavy to be put on the tail wheel.
Anybody ever made one, seen one or know where I can view pictures of one?
tailwheel tie down release
I have the same thing - I use it for getting a Cub started, when I am on my own. Rather overpriced; I found the same shackle at a sailboat chandler for about 8 bucks. It works well when you get it just right. Sometimes after tugging on the release string, the restraining string gets stuck in the tailwheel assembly and you need to climb out again. Once I decided to simply throw out the release cord, since I was only staying in the pattern - I came back to find I spent an hour doing touch & go's with the thing trailing behind me. It looks a little worse for wear now.
"Someone already thought of that."
