My home field is 7,100' elevation and this type of crash is somewhat common. You can almost bet the pilot did not lean for best power.ussyorktown wrote:
Yah, did you calculate the density altitude, weights and balance, crosswind factor, fuel on board, or did you just forget all that to get out of this stupid desert? (and the fuel is so rich it would choke a Russian gangster)
The video says it all
- CharlieTango
AOPA Interview with the pilot
Drew
PP-ASEL
PP-ASEL
AOPA.COMCritics have not been shy about taking Gropp to task for various decisions, including an attempted liftoff at altitude with a fully enriched mixture, and failure to abort the takeoff once the ground roll stretched to excessive length.
Yeah. Critics here said that and more.
Interesting that pilot broke his jaw. He was leaning forward anyway.
So his face hit the dashboard. CTSW has better seat belts. I've tested them and can only lean forward about 8 inches so hopefully if I go down won't have my face marry the instruments.
xxx xx xxxx
