Here is a new enhanced Rotax class that everyone has been asking for its return. For a change I could use some help. I need help in spreading this out to other forums since I'm not on as many forums as others here. Please spread the word and copy and paste to other aircraft web sites.
Thank You
This is a two day class.
Date: Oct 14 & 15 or Nov. 11th & 12th, 2023 (0800 hrs. – 1700 hrs) Cost: $425
Do to the hands on work a maximum class size is 10-12. We want everyone to be involved. Pre-registration is needed because classes are usually full.
Phone: 520-349-7056 or Email: [email protected]
This is an improved service level class that will raise and improve the 100 hour and annual inspection understanding. It will guide people to perform at a higher level of education and knowledge base whether you are a private owner or a mechanic. After discussions and feedback with the students that have taken this enhanced Service class with mostly hands on instruction they feel like they are capable of performing at a higher level with inspections, performing simple service work and documenting in the logbook over some other service classes. This class will have a couple hours of classroom each day, but the majority of each day is all hands on work with a functioning Rotax 912ULS and a 912iS engine and targeting the 100 hour / annual inspection and general service work. We will perform an actual annual inspection on a functional aircraft and every student will be supplied with an inspection checklist. We will demonstrate and perform other service functions. While working you will be able to ask real time questions and take notes to help your understanding of the work when you return home. This will empower owners and mechanics to perform better 100 hour and annual inspections, better DOCUMENTATION, and service-based maintenance on the 912 engines. This class will expand on the already successful Rotax Service class by incorporating more hands on time, but more importantly it will expand on better logbook documentation and will focus on a more detailed and proper inspection process while performing service-level work on the 912 UL, ULS & iS class engine and the 914 engine. This enhanced class will help reduce maintenance induced engine problems and simple time consuming inquiries to the Rotax distributors’ and owners’ maintenance based questions.
Classroom instruction: Each day is 3-4 hours of classroom with engine part props
1. Registering engines
3. Proper use of hose clamps, clamping techniques and the tools. Types of clamps and demo each including Oetiker, Band-It, fuel injection clamps and the constant compression spring clamps.
19. Gearbox removal and installation. We will disassemble a gearbox just to allow students to see its interior parts operation (no maintenance, just prep for shipping to a distributor)
22. Fuel pump replacement
28. Proper prop pitch setup demonstration. This seems to be a big one for many people. Many owners and A&P’s don’t know how to do this and it’s important for the engine.
__________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
Tucson, AZ Rotax Service Class Details
Oct. 14 & 15 or Nov. 11th & 12th, 2023
The class is Oct. 14th & 15th or Nov. 11th & 12th, 2023 (Saturday & Sunday). The class will start promptly at 0800 each day. There will be classroom presentation in the Ryan Airfield conference room each day in the morning and work in the hangar each day after the class presentation. There will be a lunch break each day at approximately 1130 hours.
Please bring a laptop or tablet device in case you need to find Rotax information and manuals on line. There is Wi-Fi in the classroom.
The class is being held at Ryan Airfield (KRYN) in Tucson, AZ. (9698 W Ajo Hwy). This is west of Tucson proper and city limits and approximately 15 minute drive from the Tucson Airport (TIA). If you fly in your own aircraft parking is right up at the back door of the conference room. Rental cars are available at Tucson Airport or Enterprise car rental on Valencia road and Uber can pick you up at Ryan if you need a car from there.
Directions to Ryan Airfield are as follows and can be reached by either Ajo Hwy or Valencia Rd. They both run right in front of Ryan Airport. The conference room is up front at the airport on Ajo Hwy. It is the only building out on Ajo Hwy and the only parking out on Ajo Hwy.
If you are staying in Tucson central or out by Interstate 10 then take I-10 to I-19 south. Immediately exit west onto Ajo Hwy. Follow this road 12 miles out to Ryan Airfield.
If you are staying in a hotel out by Tucson Airport off Valencia Rd. Just head west on Valencia until it dead ends right at Ryan Airfield on Ajo Hwy. or for a unique experience Casino Del Sol at 5655 W Valencia Rd. just 5 minutes down the road from Ryan Airfield. This is a large Native-American Casino.
There is a restaurant at Ryan field. There a two other restaurants in the area. We can share cars.
For questions call Roger Lee in Tucson, AZ at 520-349-7056
Rotax class for 2023.docx25.19 kB · 0 downloads Rotax class directions 2023.docx12.96 kB · 0 downloads
Tucson, AZ.
LSRM-A , Rotax Instructor & Rotax IRC
Specializing in Light Sport and Rotax Engines
520-349-7056 Cell
Rotax Enhanced Annual and Service Class Oct. 15th & 16th, 2022
Re: Rotax Enhanced Annual and Service Class Oct. 15th & 16th, 2022
B
There are two seats open for the Oct. 14&15th 2023 class and five for the Nov. 11&12 2023 class.
