Rotax 912ULS or Jabiru 3300
I see that the CZAW Sport Cruiser has the option of the Rotax or the Jabiru engine. Does anyone know the pros and cons of these engines?
Thanks,
Jeff
Thanks,
Jeff
Ahhh, what an awful dream. Ones and zeroes everywhere... and I thought I saw a two.
- CharlieTango
- Paul Hamilton
Rotax 912 mystery
Check out the video trailer on the 912 half way down the page to provide some background on the 912
http://www.ap-store.com/asaf2f912.html
True, but read the Rotax service bulletin carefully. The very newest 912s (by s/n) are automatically upgraded to 2000 hr TBO. The slightly older ones (including mine; the SB lists which s/n's) require that one screw and one spring be changed. (The parts list for under $40). The oldest ones require replacement of some crankcase parts, so I don't know how practical (or expensive) the mod will be for those.bitten192 wrote:912ULS just upped their TBO to 2000hr.
In any case, as I read it, to comply with the SB, one must overhaul the gearbox at 1000 hrs.
There is a huge philosophical difference in these two engines. Don't know if it matters to you or not..
The Jab is a 6 cyl. and runs smooth as silk and is relatively quiet. It's direct drive and air cooled so it's as dirt simple as a Conti or Lync. It's a 125 HP so its about 30 more than the Rotax, and this is a LOT.
The Rotax is a 4 cyl and there is no way anybody could call it smooth, even though cruise RPM is around 5000 to 5200. It's water cooled, which adds complexity, but avoids issues like shock cooling that you can have in air cooled engines.
Historically the Jab has had cooling issues, but from what i've been reading, the newer installation have that sorted out. The Rotax has had issues with the gear box, but again, these have been addressed and newer installations seem to be rock solid.
I fly behind a 912ULS but have only been a passenger behind a Jab. The Rotax has an excellent service record and there are starting to be shops that can work on them. This might be more of issue with a Jab. The deciding factor for you may be the availability of a mechanic.
Personally, I love the smooth running and quiet Jab, but if I were putting my money down, don't know what I'd do.
Ron
Ron
I've flown them both, Ron, and I generally agree with your comments about smoothness, simplicity, and philosophy. However, I chose to purchase a Rotax-powered S-LSA for one reason not previously mentioned: ubiquity. The Rotax powers about 80% of the S-LSA fleet. This means parts and mechanics are more abundantly available than is the case for the Jabiru.rsteele wrote:I fly behind a 912ULS but have only been a passenger behind a Jab.
Have you mechanic properly balance the carbs...you'd be surprised how smooth you can get that engine to run when each side is producing the same amount of power.rsteele wrote: The Rotax is a 4 cyl and there is no way anybody could call it smooth, even though cruise RPM is around 5000 to 5200.
Adam
CFI-SP, Light Sport Repairman - Maintenance, Rotax Cert.
Orlando, FL
Orlando, FL
Very true.FLA-CFI wrote:Have you mechanic properly balance the carbs...you'd be surprised how smooth you can get that engine to run when each side is producing the same amount of power.rsteele wrote: The Rotax is a 4 cyl and there is no way anybody could call it smooth, even though cruise RPM is around 5000 to 5200.
Roger Fane
