Avionics
EyeInTheSky
Avionics
Postby EyeInTheSky » Wed Sep 25, 2019 8:21 pm
Hello. I realize that there are some restrictions on what can be installed on general aircraft and by who, but am wondering if I can put a ADF in a LSA if I wanted to, or is there a formal FAA process that needs to be completed? How about a ham radio with external antenna?
Thank you.
Student Pilot
M.S. Management and Leadership
C.A.P. Senior Member
Re: Avionics
Postby TimTaylor » Wed Sep 25, 2019 8:30 pm
You can't do anything with an S-LSA without a LOA from the manufacturer. I think you can do almost anything you want with an E-LSA. Why an ADF, to listen to music?
Personally, I think a pilot ought to concentrate on flying, not being entertained or any other distractions.
Re: Avionics
Postby 3Dreaming » Wed Sep 25, 2019 10:31 pm
The process you have to follow depends on what type of airworthiness certificate the airplane has.
EyeInTheSky
Re: Avionics
Postby EyeInTheSky » Wed Sep 25, 2019 10:49 pm
Got it. Thank you.
Student Pilot
Re: Avionics
Postby 3Dreaming » Thu Sep 26, 2019 8:19 am
An experimental requires no approval. A SLSA requires approval from the manufacture, they are required to track any changes to the aircraft per ASTM standards. A standard category aircraft at a minimum requires a logbook entry, but may also require a STC or field approval from the FAA.
Scooper
Re: Avionics
Postby Scooper » Thu Sep 26, 2019 9:16 am
EyeInTheSky wrote:Hello. I realize that there are some restrictions on what can be installed on general aircraft and by who, but am wondering if I can put a ADF in a LSA if I wanted to, or is there a formal FAA process that needs to be completed? How about a ham radio with external antenna?
Thank you.
If it's an SLSA, you'll need a letter of authorization (LOA) from the manufacturer. There will be a lot of back and forth discussion and paperwork involved at the least.
If it is an ELSA you can install your own avionics, but unless you are the builder with a repairman certificate, or have a light sport repairman - inspection certificate, you'll need to have the annual condition inspections performed by a certificated A&P mechanic or a person holding a light sport repairman - maintenance certificate. After completing the condition inspection, the individual performing the inspection will certify in the aircraft logs that the aircraft is "found to be in a condition for safe operation." Generally, that means the installation conforms to AC 43.13-1B/2A, and that the weight and balance calculations have been revised to reflect the installation.
I intend to install my Elecraft KX-2 amateur band HF transceiver in my ELSA sometime in the near future.
Re: Avionics
Postby drseti » Thu Sep 26, 2019 9:58 am
Scooper wrote:I intend to install my Elecraft KX-2 amateur band HF transceiver in my ELSA sometime in the near future.
Let me guess, Stan - you're going to run CW while flying?
I haven't done aeronautical mobile in about 40 years. Flying is just too much fun for me to want the distraction. But I did have antennas and a rig interface to the audio panel installed in the Beech via a 337.
Scooper
Re: Avionics
Postby Scooper » Thu Sep 26, 2019 11:01 am
Heh heh.. I don't have an autopilot, Paul, so my plan is to have a buddy fly the plane from the right seat while I play with the radio (both CW and SSB). I have a small keyer paddle that straps to my right thigh near my knee that gives me a very comfortable keying position. My KX-2 has a very capable automatic antenna tuner built-in, and right now I plan to rig a long wire from the rudder to the right wingtip. Since the Zodiac doesn't have a vertical stabilizer, I'll use a spring to keep the wire taut as the rudder moves.
73,
Stan
Re: Avionics
Postby Wm.Ince » Thu Sep 26, 2019 11:35 am
3Dreaming wrote:An experimental requires no approval. A SLSA requires approval from the manufacture, they are required to track any changes to the aircraft per ASTM standards. A standard category aircraft at a minimum requires a logbook entry, but may also require a STC or field approval from the FAA.
Excellent info, Tom. Thank you.
CTSW (E-LSA)
EyeInTheSky
Re: Avionics
Postby EyeInTheSky » Thu Sep 26, 2019 2:53 pm
It sounds like installing a 2 meter transceiver may be a bit easier. I wanted to have something a bit more permanent than using a portable.
Student Pilot
Scooper
Re: Avionics
Postby Scooper » Thu Sep 26, 2019 3:45 pm
EyeInTheSky wrote:It sounds like installing a 2 meter transceiver may be a bit easier. I wanted to have something a bit more permanent than using a portable.
A VHF transceiver would clearly be much easier, Sean. I've used a 2 meter HT aeronautical mobile from my 172 operating on 146.52 simplex, and it was a blast. I haven't tried it yet in the Zodiac.
73,
Stan
EyeInTheSky
Re: Avionics
Postby EyeInTheSky » Thu Sep 26, 2019 7:09 pm
Excellent! So it is a matter of taking a mobile 2 meter rig and mounting it in the aircraft, or is it more involved? I imagine that simplex at elevation would go for miles!
Student Pilot
Re: Avionics
Postby drseti » Thu Sep 26, 2019 7:55 pm
EyeInTheSky wrote: I imagine that simplex at elevation would go for miles!
True. Assuming a spherical Earth (a good first-order approximation), VHF line-of-sight propagation distance in miles equals 1.23 × sqrt (h) where is height in feet. So, at an altitude of 10,000 feet, we're talking a simplex range of 123 miles.
Re: Avionics
Postby TimTaylor » Thu Sep 26, 2019 8:15 pm
So, what is the purpose of this?
Re: Avionics
Postby drseti » Thu Sep 26, 2019 8:34 pm
TimTaylor wrote:So, what is the purpose of this?
Like all conversations between ham radio operators, our purpose is to communicate.
Return to “Ask The Mechanic”
