Agreed.Jack Tyler wrote:But having said all that, I don't see it as a necessary tool for the VFR pilot .
I have my Dynon D10A as a backup to the real horizon outside the plane.
A VFR pilot, with proper training and planning, should never lose the real horizon in the first place. But it can and does happen, so having some way to know up from down is nice to have. Having a backup to the backup, however, seems a bit extreme.
In my plane, primary navigation is my 496. It has enough information, including weather via Sirius, to safely navigate in most cases, but...
1) It lacks some info on the sectional, and so likely fails as a source of the "all available information" the FAA requires for any flight "not in the vicinity of an airport".
2) It's very expensive to update, so my habit is to update the aviation and obstacle databases annually.
3) Therefore, I use the information on my iPad Mini via WingXPro7 as my primary information source.
4) And my backup to that is my iPhone, also running WingXPro7 and kept current. Kinda small for routine use of the sectional, but about the same size screen as most of the Garmins many of us got used to over the years and fully usable in a pinch.
5) I do have a handheld COM, but most of my flying is done where there are mostly non-towered airports in any case, so I don't always have it in reach. Probably not a bad idea, though.
