Allegro LSA
Posted: Sun Dec 30, 2012 5:44 pm
by mhaleem
Does anyone have a list of procedures for sport pilot maneuvers specific to the allegro? Looking for speeds associated with these maneuvers and have looked at POH. I have seen such lists for the Remos and other LSA's but nothing for the Allegro. Example steep turns, slow flight, power-on, power-off stalls, etc. Thanks
Re: Allegro LSA
Posted: Mon Dec 31, 2012 5:26 am
by ka7eej
Here is some information taken out of the 1232 lb Allegro 2000 manual.
Maneuvering and Gust Envelope
Operation Limitations – Allegro 2000
Limiting Speeds (never to be exceeded):
Wing flaps Lever position Flaps Deflection Never Exceed Speed
Cruise position 0 -4,5 ° VNE 138 MPH
Take-off 1 15 ° VFE 68 MPH
Landing 2 48 ° VFE 68 MPH
THESE SPEEDS MAY NOT BE EXCEEDED UNDER ANY CIRCUMSTANCES !!!
Allegro Flight Manual - October 2005 Page 14
Revision 12-8-05
Stall Speed at maximum take-off weight 1232 lbs. - level flight
Stall Speed
Wing Flaps Position Engine Power Output IAS MPH CAS MPH
0 Engine at idle 53 MPH 51 MPH
1 Engine at idle 48 MPH 47 MPH
2 Engine at idle 45 MPH 44 MPH
Maximum Level Speed with extended flaps VFE = 70 MPH
Caution - Do not exceed this speed with extended flaps!
Design Maneuvering Speed VA = 90 MPH
When flying faster than this you must not suddenly use the full deflection of the
rudder and elevator nor do any quick maneuvers otherwise an overload to the
aircraft could occur. Do not exceed this speed in turbulence +-2000 fpm!
Service ceiling
15,000 feet - Note: Sport Pilot Rules limit ceiling to 10,000 ft.
Limiting Wind Speeds
Maximum Demonstrated Headwind Speed 23 mph
(i.e. against the direction of the flight)
Maximum Demonstrated Crosswind Speed 12 mph
(i.e. perpendicular to the direction of the flight)
Do not try to take off or land with the tail-on wind except for emergencies!
Weights
Minimum Front-Seat Pilot Weight 120 Lbs
(ballast may be added to meet weight)
Maximum Weight of the Crew and Fuel 594 Lbs
Baggage Weight 22 Lbs
Maximum Take-off Weight 1232 Lbs
Empty Weight 638 Lbs
What else do you need???
Brian
