Page 1 of 4
Looking for next plane - is a C162 a good option
Posted: Thu Feb 09, 2017 4:33 pm
by c162pilot
Recently sold our 2011 DA40-XLS and I am now looking for next my next plane. Decided to go the S-LSA route. Looking at CTLS/CTLSi, Tecnam P2002, RV12 amongst others. Some of you may recall I once had a deposit on a C162 Skycatcher but cancelled the order when Cessna jacked up the prices. Just spoke to a friend of mine who recently sold his C162 for $48,5000. I notice there were quite a few C162's on the market and I am sure I could find one for around $50,000 which is almost half of what all the other planes I am looking at would cost. I did get checked out the in C162 and if I can live with the limitations of the C162 would it be a good decision to buy a C162 in the fifty thousand dollar range if you are looking for a run about for the next few years?
Re: Looking for next plane - is a C162 a good option
Posted: Thu Feb 09, 2017 6:45 pm
by joey4420
I personally could not live with one, but that is me. I am flying one in training and yes the cost would be good, but the load factor is what gets me. That and even though the one I fly is in a flight school it has just over 1000 hours and had to have an engine rebuild due to metal in the oil filter.
Posted: Thu Feb 09, 2017 7:27 pm
If you fly 90% of your time solo, as most of us do, then the useful of a 162 is fine. If you want to do long travel legs with a passenger, it might be a bit frustrating.
Posted: Fri Feb 10, 2017 10:35 am
eyeflygps wrote:In that case, you go with 3/4 fuel and 2 hour legs with 1 hour reserve. Not a problem for me, but would be for some people.
Which is fine for a day trip, but when traveling that won't leave any room for baggage with most normal-sized humans. I guess you could go to half fuel and one hour flight legs with an hour reserve, which gets you 35-40lb of baggage with two 180lb people.
Posted: Fri Feb 10, 2017 1:38 pm
by Wm.Ince
eyeflygps wrote:486-108 (3/4 fuel) = 378
378-360 (occupants) = 28
Pack light or get smaller friends. It's not going to work for everyone.
With Our CTSW's, we don't have to compromise on either one.
Posted: Fri Feb 10, 2017 1:47 pm
378-360 = 18. Get really small friends.
Posted: Fri Feb 10, 2017 2:01 pm
Wm.Ince wrote:eyeflygps wrote:486-108 (3/4 fuel) = 378
Well...sort of. My airplane with full fuel and two 190lb people is 10lb overweight. But that is with 34 gallons of fuel. At 20 gallons (2.5 - 3.0 hours plus reserves), I have 75lb for baggage.
Even in a "heavy hauler" (HA!) LSA like the CTSW, It's still tough to travel long distances with a passenger and decent baggage. I don't like going much below 7-8 gallons of fuel on landing because the CT's fuel system quirks, so in reality I'm back down to 2.5hr legs. Useful travel in an LSA with a passenger is just hard to do. I think the Bristell has a bigger load, as does a Highlander. But the latter is slow, which causes other travel issues.
Posted: Fri Feb 10, 2017 6:26 pm
Here's the cheat sheet I use in my (porky) Sky Arrow:
Before buying a plane, its wise to come up with something like this and see if it meets your mission profile.
While I'd love more useful load and range, I can live with what my plane delivers. Karen weighs little enough the we can carry full fuel - albeit only 18 gals - and a reasonable amount of luggage if needed and still stay under 1,320 lbs.
As a side note I just hammered my weight down to 179. If I can keep it there (or lower) that helps a lot as well!
Posted: Sat Feb 11, 2017 4:05 pm
by HAPPYDAN
I like your weight and balance chart. Is that a spreadsheet? Do you mind if I copy that (with mods, of course) for my own use? You know I like the Skycatcher, but lately I have become interested in the Legend Cub. Probably has an even worse useable load, but the most fun I've had flying was in a1936 (restored) Piper Cub. I liked the steam gauges too. If you can't have fun, what's the point?
Posted: Sat Feb 11, 2017 5:00 pm
It's in Excel.
See if it attached properly. If not I can maybe email it to you or give you a DropBox link.
Just please double check both my formulas and your own!
Posted: Sat Feb 11, 2017 6:19 pm
HAPPYDAN wrote: Probably has an even worse useable load, but the most fun I've had flying was in a1936 (restored) Piper Cub.
I guess you are lucky. Not many people get to go for a ride in a 1936 Piper Cub. The puny 37-40 HP of the J2 would only carry 2 people aloft in the best of conditions.
Posted: Sun Feb 12, 2017 1:04 am
by HAPPYDAN
3Dreaming wrote:HAPPYDAN wrote: Probably has an even worse useable load, but the most fun I've had flying was in a1936 (restored) Piper Cub.
My father soloed in a J3 in 1942, so it was kind of a discovery mission. The plane is owned by Safety in Motion, Puyallup WA (KPLU). Hand propped, 65 hp Continental, hand held radio. It took them 2 weeks to find a qualified CFI, but is was worth every minute and every penny. Low and slow.
http://sportpilottalk.com/download/file ... iew&id=558
Posted: Sun Feb 12, 2017 1:35 am
by HAPPYDAN
FastEddieB wrote:It's in Excel.
Thanks much! This is a good format and looks to be easy to work with and modify as needed.
Posted: Sun Feb 12, 2017 8:04 am
Happy to help!
Probably obvious, but I'll state it anyways for the newbies:
This stops one step short of the "balance" part of "weight and balance" - one still needs to apply the resulting cg to the manufacturers cg envelope to be sure it's within limits. One will get a feel over time about what sort of loadings start approaching or exceeding cg limits. It's a good exercise to see what it takes in a "worst case" scenario to end up out of limits. In my Sky Arrow it's virtually impossible to do, but it's not unusual for a Light Sport to start hitting its forward cg limit with a heavy pilot and passenger and no baggage.
One solution is to carry a collapsible water container that can be filled and secured in the baggage compartment as ballast.
Posted: Sun Feb 12, 2017 10:13 am
by joey4420
eyeflygps wrote:Load factor? I think you mean useful load. 486 pounds useful load works for me.
Yes I meant Useful Load, sorry it was a long day at work and my terminology was off.
