Gobosh fuel
arizonarotors
Gobosh fuel
Post by arizonarotors »
Hi,
I'm trying to find out if E10 auto fuel is safe to use in the Gobosh.
I've read the appropriate Rotax documentation and it is clear E10 is okay for this particular engine.
I know the Gobosh has a composite tank. I'm trying to determine if this composite tank is adversely affected by E10.
Thanks,
Jim
Re: Gobosh fuel
arizonarotors wrote: Wed Aug 11, 2021 4:12 pm Hi,
Thanks,
Jim
Check the Gobosh operating and service manuals, Jim. There can be lots of things in the fuel system that could be adversely affected by ethanol. If the manuals don't specifically list E10 as an approved fuel for the airframe, I wouldn't chance it. Some manufacturers test for ethanol compatibility - I'm not sure whether Gobosh ever did.
arizonarotors
Re: Gobosh fuel
Thanks for the reply Paul.
For folks that are accustomed to Lycoming and Continental engines and 100LL fuel, this stuff can be.............interesting.
I keep reading about how bad 100LL is for 9 series engines and many of the airframes; but then simultaneously read about how bad E10 is.
Confusing doesn't begin to describe it.
Seems like the safest course of action is to run 100LL and accept shorter maintenance intervals.
Thanks again,
Jim
