TL Ultralight Stingsport
Re: TL Ultralight Stingsport
It shouldn't take to long, I would guess no more than an hour, and likely much less. If you know anyone familiar with glider rigging you could ask them for help. The process is very similar to how many modern gliders are assembled.
I have a 2006 Sting Sport and I do the stabilizer inspection every other annual. It's not difficult and takes an hour or so when you include the time needed to re-caulk. It is easiest if you have a helper to help lift and position it.
____________________________
2006 Sting Sport SLSA - N686N
PPL-ASEL, LSRM-A, iRMT
Thanks for the info.............. much appreciated
I use GE II silicone, as the manual recommends. I get the white exterior (door and window) caulk.What caulk do you use?
