My bad luck ( or my learning curve ) continues
Went for a flight today, very nice weather , a bit bumpy and rather cold with only 10F.
I have flown in about 3F so I wasn't worried - the oil was OKish etc but ...
About 10 minutes into a flight I heard a crack followed by some moderate wind noise ( which quickly went away .) Couldn't figure out what it was but decided to land anyway and after walking around the plane a few times I finally spotted the culprit.
It was the plexiglas around the GRS window grommet - it cracked a bit and I can only assume it was due to cold weather combined with some minor bumps.
I landed at my mechanics place so we drilled the hole to stop the crack but it does look like I will have to replace the back window and the grommet. Oh well, another expense and another lesson learned - don't fly in cold weather .... how cold , well my new limit is 32 F
Winter Ops
Winter Ops
- crack2.jpg (91.19 KiB) Viewed 11071 times
- Cracked Plexiglass
- crack1.jpg (61.71 KiB) Viewed 11071 times
Re: Winter Ops
Damn, that really Stings.
Re: Winter Ops
Got in touch with the dealer (Bill Canino ) and he basically told me that he has seen the exact same crack in one other Sting and they simply covered it with some black electrical tape and since the canopy ends where the crack ends no further action was required unless I was concerned with the visual aspects of it.
I am but will see how much I get quoted for fixing it - I may stop being concerned with the visuals if it is too much
Re: Winter Ops
Actually this crack was within the window itself which is basically some kind of acrylic. The actual culprit here is most likely the design ( or positioning to be more specific ) of the GRS groomet mini-window itself with it being so close to the edge of the canopy - you end up with a weak and narrow spot that can crack.
The choice of carbon or metal for the plane itself was irrelevant here. There is no structural body damage here and the visible crack is just the outer-skin affected by the cracked acrylic underneath.
Re: Winter Ops
If you want to see just what's involved in repairing a (much more severely) cracked plexiglass canopy, see my Near Midair Collision webinar at:
http://www.eaavideo.org/detail/video/4890470314001
Re: Winter Ops
They have transparencies that can crack too. It is not something that is relegated to composite airplanes.TimTaylor wrote:Another reason I prefer the SkyCatcher and RV 12.
Re: Winter Ops
DrSeti: I actually have seen this video before , pretty freaky near mid-air - didn't pay attention to the canopy repair portion back then though
Anyway, I will probably not bother replacing anything there for now since the crack is so minor and can be handled rather cheaply but boy I am wondering if I am just unlucky or other plane owners have similar issues with minor cracks/fixes etc ... I just started flying , if that's the norm I am not sure I want to continue
Re: Winter Ops
I have owned several airplanes over the years, and have not had any crack transparencies. As a mechanic though I have replaced some that have been cracked for customers. I wouldn't say that it is a common problem, but some airplanes seem to have more issues than others.Warmi wrote:DrSeti: I actually have seen this video before , pretty freaky near mid-air - didn't pay attention to the canopy repair portion back then though
Re: Winter Ops
Very unfortunate.Warmi wrote:My bad luck ( or my learning curve ) continues
Re: Winter Ops
I was actually recording this flight and managed to catch that very moment it happened ...
- Jim Hardin
Re: Winter Ops
Sorry Bob, gotta ask... I was surprised in your Florida incident that the Controller continued his rapid speech when it was clear you had noise and confusion.drseti wrote:If you want to see just what's involved in repairing a (much more severely) cracked plexiglass canopy, see my Near Midair Collision webinar at:
Not sure I would have made any reports after landing until I was sure my adrenalin level was back down to normal
With all the expenses, I assume you filed a claim. Did your insurance company attempt to subrogate for their loss?
Re: Winter Ops
I was very lucky, Jim. I filed a claim as soon as I finished talking to FAA and filing my NASA ASRS report. They were great about working with me, and paid everything except my $1000 deductible. No subrogation of which I am aware. Didn't even raise my premium the following year. My carrier is Starr, and I work through Falcon, the EAA Insurance Agency in Kerrville TX. Can't say enough good things about them.Jim Hardin wrote: With all the expenses, I assume you filed a claim. Did your insurance company attempt to subrogate for their loss?
And, folks, please do forgive the thread drift.
Re: Winter Ops
Back on point, and the thread title, I don’t really think cold weather was a major contributing cause here.
Sure, many materials get more brittle at cold temps, but a plane should be capable of flying in any foreseen temperatures without parts starting to crack.
Re: Winter Ops
Yeah, it is hard to say. Probably come kind of combinations of minor manufacturing issues, naturally weaker spot to begin with ( the narrowest part ) and maybe a bit of cold, bumpy weather.
It is a very minor crack -it actually looks worse on the picture than in real life and I already have a fix for it which was pretty cheap, looks good and has been approved by the dealer.
If that was some kind of common occurrence , I would start asking more questions but since, as I was informed, this is only the second plane that had this issue ( out of many hundreds sold) I can only guess that it was some kind of manufacturing issue with the plexiglass canopy part in the first place. I mean, it was a bit bumpy that day, but as you can see on the video, it wasn’t putting any kind of undue stress on the airframe.
