Ready for winter flying
David
Post by David »
Getting ready for cold weather flying - oil shutter installed to keep engine temps up at -10
Installed seat heaters for me - keep my temps up!
David
EAA 1250 KPTW PA
akroguy
Re: Ready for winter flying
Post by akroguy »
Nice setup!
It was only around 60 deg. F yesterday and my oil temp barely made it into the normal range.
Where's that roll of duct tape..
2006 Evektor Sportstar SE
E98 Los Lunas, NM
60 F ?
My plan this year is not to whip out the tape until it gets below 30 :D
Today actually was 39 F or so - pretty chilly but on the other hand, I love the fact that 1200 FPM climbs are coming back !
Also , enjoying fall colors ...
rideandfly
Post by rideandfly »
David, Nice looking oil/shutter rig!
Warmi, Excellent shot!
Agree, use tape to raise oil temp, trying some 2" white electrical tape.
The Vag does not have a VSI, will time a climb to see how it's climbing in the cooler weather.
Set up a pre-heater rig, will see how it works soon:
Bill
48 PA-17 Vagabond
Riggson
Post by Riggson »
Did you have a chance to try that Honda EU2000 yet, Rideandfly? Are you satisfied with it?
I'm a huge supporter of ExpressVPN because it's great.
chicagorandy
Post by chicagorandy »
I have had quite a bit of jobsite use with the Harbor Freight Predator 2000 (basically a 1/2 priced clone of the terrific Honda machine) and it has proven itself worthy.
https://www.harborfreight.com/2000-watt ... 62523.html
rideandfly
Riggson wrote:Did you have a chance to try that Honda EU2000 yet, Rideandfly? Are you satisfied with it?
Happy with the Honda, been using it a few years camping. Tested it with the pre-heater and it works fine, too. Pre-heater is rated for a maximum draw of 1500W. The Honda gen-set is rated for a continuous output of up to 1600W.
Use the Honda 2000 running a 13.5K Dometic AC unit on a camper. Installed a Micro-Air EZ start on the AC so the gen-set would start the AC compressor. Latest Honda available is a 2200 unit.
chicagorandy wrote:I have had quite a bit of jobsite use with the Harbor Freight Predator 2000 (basically a 1/2 priced clone of the terrific Honda machine) and it has proven itself worthy.
Many folks use the Predator, understand it's a fine unit, too.
Bill
48 PA-17 Vagabond
