Need a new Handheld Icom or Vertex or Sportys
- azsportpilot
- Contact:
I had a Vertex (yaesu) VXA-720
very cool looking with metal body and waterproof...... but
It was extremely complicated with multiple useless features buried deep in multi layer menus
I thought it was me and handed it to several of the younger pilots at the airport and said simply "put it on 122.9 for me"
none were able.... so I sold it cheap with the caveat that the buyer assumes the risk that the unit may be broken or something as Vertex was not able to talk me through changing the frequency either
the buyer emailed me 3 days after he rec'd it and said he got it working (apparently it was in memory mode and while in memory mode the freq cannot be changed, he also went on to say it took him 3 full days to figure it out and determine how to cancel the memory mode) good grief
he was a 27 year old IT professional and it took 3 days
I really love the look of the new VXA-750L with GPS but in reading online reviews it seems it is equally non-user-friendly
so on to Icon... no GPS available, but good reviews.... except for the guys in the helicopter forums complaining that only the older discontinued Icon's work with a headset.....the new models will not transmit through a headset, I'm assuming this is specific to the helicopter headsets using a U-174/U type plug, but I can't confirm that
apparently it might work if you install "Ferrite Beads" huh?
http://www.pprune.org/archive/index.php/t-434376.html
and
http://www.rotaryforum.com/forum/printt ... 3121&pp=40
The sportys seem cheaper made but not in price, any experience with them?
I want a Handheld that is as easy as an iPhone to use, (not blackberry-Vertex complex)
I don't need a memory function, I just want it to work, I want to be able to use it and change frequencies during an inflight emergency with one hand.... I won't have time to re-read the manual when i need it
any suggestions?
do the Icons work with a headset?
is the Sporty's as flimsy as they look?
does Vertex make anything a guy with an IQ below 140 can operate?
and
any suggestions?
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
Re: Need a new Handheld Icom or Vertex or Sportys
I'm very interested in hearing responses as well.
- azsportpilot
- Contact:
mypilotstore has a cool comparison chart, but it doesn't tell me what i really want to know
1- ease of use
2- headset compatibility
http://www.mypilotstore.com/mypilotstor ... ceiver.asp
check it out lots of info
looks like they are all more similar than different
all are 5 watts
all have 3 yr warranty
all use BNC antenna connector
all weigh between 12-15 ounces
all are between $200-$400
though obviously the Sporty's ones didn't make the comparo chart as it is a Sporty's exclusive product
1- ease of use
all are 5 watts
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
I think the ICOM A-14 is going to be the easiest/simplest.
Also has a big Li Ion battery.
For basic COM only, I think the A-14 is the way to go.
- azsportpilot
- Contact:
looks pretty basic and well madepjcampbell wrote:I think the ICOM A-14 is going to be the easiest/simplest.
i really like the 2000mAh Lithium-Ion barrery
Looks like the A-14 goes for $205 (headset adapter not included) so when you add the adapter $40... you are at $245
for $255 ($10 more) you can get the IC-A6 which includes the headset adapter... plus possibly other features
the IC-A6 has 8.33 kHz channel spacing for Europe.... but who cares, and the IC-A6 seems to downgrade you to the 1650 mAh Ni-MH battery
Last edited by azsportpilot on Wed Jun 01, 2016 12:04 pm, edited 3 times in total.
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
I read the reviews of the Vertex before I bought mine and the ONLY complaint was the complicated UI.
I have to say I don't see the problem. Maybe it's one of those thing you "get" or not but I found it pretty easy to use. 30 minutes with the manual and I pretty much had it mastered. And, I certainly don't claim to be especially adept at user interfaces or user manuals. Mine is the older model with the VOR. Way easier to use the the latest iPhone which seems to want to hide as much functionality as possible.
Ron
Ron
- azsportpilot
- Contact:
I think people buy a handheld for one of two reasons
A- to listen to the tower while they stroll around the exhibits at oshkosh AirVenture
or
B- as a tool to use when the electrical system fails in turbulence as they enter the class Bravo
in the case of user type "B" there will be no time to read the manual
or
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
Here's the comparison for the 14 and 14S. Appears to be NAV and weather, and 100 more channel memory.
http://icomamerica.com/en/products/avio ... tions.aspx
- azsportpilot
- Contact:
don't need NAV, weather is nice, don't need memoryCluemeister wrote:Here's the comparison for the 14 and 14S. Appears to be NAV and weather, and 100 more channel memory.
looks like with the cheaper "S" model ($209.00) you also lose the "Direct enter keypad" thereby having to slowly advance through the frequencies using up/dn arrows... that's a problem
the "non-S" version ($214.00) for nine dollars more you can simply type 1-2-2-9 when you want 122.9
https://youtu.be/vzIapM6HDkA?t=29
I don't think I will ever feel the need to track a localizer, and use the VOR to shoot an ILS approach in my LSA using my handheld radio
I wonder if the $255.00 IC-A6 offers any tangible advantage over the IC-A14 other than the Headset Adapter being included
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
[/quote]
[/quote]
For $9 you get NAV (GPS could go out, you never know), weather, more memory, and direct punch in of numbers.
[/quote]
- azsportpilot
- Contact:
Agreed,.....for the extra $9 you get a Direct Entry Keypad.... otherwise you have to use the arrow UP/DN buttons found on the cheaper "S" modelCluemeister wrote:
that would be a real pain just to set a frequency (I believe the "S" model is designed for ground crews who never change the freq.)
If the GPS goes out I'll navigate the old fashioned way
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
The interface really isn't that hard. I just went out the airport with the radio and the manual and played with it a while, referring to the manual on how to set up memory, direct frequency entry etc. You really only need two frequencies to do that so I used AWOS and CTAF. I don't know a squat about VORs, I'm a sport pilot after all. But even that became apparent in a few minutes. Long forgotten now.eyeflygps wrote:What?rsteele wrote:30 minutes with the manual
As with a lot of tech, people have preconceived notions of how it should work. When those notions collide with how it does work it can be confusing. I know I have the same issue with computers. I used Unix/Linux for 25years before being forced to use Windows. After 10 years of intermittent Windows use I still find it confusing and frustrating. It just refuses to work the way I think it should! That's the main reason I use a Mac now. It's all good old familiar Unix on the command line and a I can run the cursed Office programs when I must.
I bought the handheld so I could listen to something while working at the airport and because I thought I was going to take lessons in a plane without an electrical system. I had 2 lessons and the instructor forgot his handheld for one of them. It was downright scary to fly in that area without a radio. So not it's a back.up.
Ron
- azsportpilot
- Contact:
Ron,rsteele wrote:The interface really isn't that hard. I just went out the airport with the radio and the manual and played with it a while, referring to the manual on how to set up memory, direct frequency entry etc. You really only need two frequencies to do that so I used AWOS and CTAF. I don't know a squat about VORs, I'm a sport pilot after all. But even that became apparent in a few minutes. Long forgotten now.eyeflygps wrote:What?rsteele wrote:30 minutes with the manual
Ron
Clearly you are extremely "Tech Savvy".... you are the perfect candidate for Yaesu-Vertex radio ownership, glad you were able to figure out their notoriously complicated platform or "UI" as you called it........ I suspect tech savvy guys like yourself are their target market
For the rest of us that do not want to learn another language and just want to pick up a radio, tune to a frequency and communicate... there is Icom..... and possibly Sporty's
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
- azsportpilot
- Contact:
exactly, I don't want to have to read the manual
I want to push a button labeled "power" or rotate a volume knob
press 1-2-2-9
and be talkin on 122.9
easy peasy
press 1-2-2-9
easy peasy
John Sarra CFI-S
1946 Aeronca Chief
1946 Aeronca Chief
Sounds to me like a great business idea. Pitch it to the Tank! I'd buy one.azsportpilot wrote:exactly, I don't want to have to read the manual
press 1-2-2-9
easy peasy
Aviation Real Estate Broker
