FastEddieB wrote:Horizon Avionics said they’d send me a written estimate.
I mentioned the GDL82. As best I can recall, these were the arguments against:
1) Installation would be more, and finding a spot for the unit could be problematic.
2} The Garmin GTX335, at about $2,700 would solve that problem.
3) I would then be free to sell my existing transponder. They seem to bring at least $500 on eBay, and he would “yellow-tag” it, making it easier to sell.
4) He predicts the GTX335 would outsell the GDL82 by a factor of 10, making service and replacement units way easier to come by.
Replacing my existing transponder antenna is straightforward. Finding a spot for the top-mounted GPS antenna less so. On my glare shield may be an option. Otherwise, drilling a hole in a composite plane is not a simple matter, and we may need to get creative.
As I said, that’s from memory, and I may be off on details.
Back to the skyBeacon, I agree with the Professor that 2 rear wingtip white position light are probably required. So I’d have to find a bright white LED to match the brightness of the one on the right wing. I have to check the wiring to my strobes. But if the skyBeacon strobes are LED, running a wire to provide 12v controlled by my strobe switch would not be too hard.
The skybeacon strobes are LED.
And I think WmInce might be onto something with what the avionics shop is telling you, the GDL-82 is extremely easy to install. I'm about to install my 3rd one for yet another owner at my airport. Possibly a 4th lined up as well if the owner ever gets off his wallet.
As far as the number of them out there, whether it's 10 or 1000 units Garmin service will always service what they sell. The number of them shouldn't effect service.
Buying the Skybeacon then means buying new lights and installing them along with new wiring for said lights just to install the ADS-B unit. I'd suggest keeping your existing transponder and lights and consider the GDL-82. I'm sure you have a spot for the unit in the plane, it's a pretty small unit. If I were closer I'd help you install it since I own all the speciality tools needed for the install. I'm in Nashville often if that gets me closer to you. This alone would save you a bundle of money as I'm sure an avionics shop is not cheap these days. Pair that savings with getting lucky enough to claim an unclaimed rebate and that's money in the bank.
The only reason I suggest the GDL-82 is because you opened this topic with "I'm looking to add ADSB to my Experimental Sky Arrow for the lowest possible price." That's the GDL-82.
