TL Ultralight Stingsport
Re: TL Ultralight Stingsport
For the red cube installation make sure to follow their instruction and install it dowstream of a gascolator.
Last year when i was installing a new avionics package my mechanic ended up installing it upstream ( right under the fuel selector in the cabin cause it was convenient )and after about 3 hours it got clogged ( because plane was sitting idle for a few months ) and failed - thankfully it failed open (as it was designed to fail) so it just stopped reporting ….
yabiah
Post by yabiah »
I have talked with a DAR and started the ball rolling to E-LSA.
I sent him pdf's of the logbooks and made an account on AWC.FAA.GOV as he requested.
He also needs to see the weight and balance along with an equipment list.
I now need to acquire the appropriate placards;
EXPERIMANTAL &
“PASSENGER WARNING—THIS AIRCRAFT IS AN EXPERIMENTAL
AIRCRAFT AND DOES NOT COMPLY WITH FEDERAL SAFETY REGULATIONS FOR
STANDARD AIRCRAFT"
For those who have E-LSA'd in the past, please let me know if I'm missing anything
or if you have any suggestions that may help this go as smoothly as possible.
Thanks,
Tim
StingSport N606N E-LSA / Retired Long-distance motorcyclist; IBA #558
If you don't have a bunch of paperwork from when the airplane was delivered new, order the CD from the FAA for your airplane.
yabiah
Post by yabiah »
3Dreaming wrote: Wed May 01, 2024 1:19 pm If you don't have a bunch of paperwork from when the airplane was delivered new, order the CD from the FAA for your airplane.
I ordered the CD yesterday.
yabiah
Stingsport Wheel Pant Spacer
Post by yabiah »
Fellow Sting owners, I'm looking for pics, dimensions and information for the MLG wheel pant spacer, AMM Fig 7.24.
I'm pretty sure the one I have is not correct and whatever I had on the other side has departed the aircraft.
Thanks
JJay
Post by JJay »
Hoping these pics help. I'm no machinist and there is a shoulder machined into one end of the barrel so I attempted to take two pics to show about how much of the barrel is machined.
____________________________
2006 Sting Sport SLSA - N686N
PPL-ASEL, LSRM-A, iRMT
yabiah
Post by yabiah »
JJay wrote: Tue May 21, 2024 10:27 am Hoping these pics help. I'm no machinist and there is a shoulder machined into one end of the barrel, so I attempted to take two pics to show about how much of the barrel is machined.
The pics are great.
I'll get them to my machinist and see what we can come up with.
Thank you!
yabiah
Post by yabiah »
JJay, thanks again for the pics.
I had a friend make me a couple spacers from Derlin 3/4" round stock.
Perfectly drilled for the 8mm bolts, no slop like my previously installed spacers.
They work great. I installed all fasteners with blue Loktite as recommended in the AMM.
Looks like the previous installer did not.
E-LSA conversion complete.
DAR requested a new W&B as there were many "weight change negligible" entries. 9lbs gained :?
And I had to do a new Equipment List. DAR $750 W&B $300
JJay
Post by JJay »
You're welcome yabiah. You'll need to change the S to and E in your signature line now: "StingSport N606N S-LSA"
yabiah wrote: Sun Jun 02, 2024 4:42 pm DAR requested a new W&B as there were many "weight change negligible" entries. 9lbs gained
I've always wondered how many negligibles it takes to make one gligible.
yabiah
Post by yabiah »
The FSDO guy that took care of my LSRI paperwork, has led me to believe that I cannot sign off maintenance or repairs to my E-LSA.
I do agree that the LSRI allows me to comply with and sign off inspections.
I would also agree that it has nothing to do with the accomplishing of maintenance or repairs.
That being said, I also believe the webinar "LSA and Experimental Maintenance (who can do what to whom)" explains that anyone can signoff minor, major or preventative maintenance on an E-LSA.
I am correct, yes?
From my Airworthiness Cert;
10. An ELSA owner/operator certificated as a repairman for this aircraft under § 65.107, an appropriately rated FAA-certificated mechanic, or an appropriately rated FAA repair station may perform the condition inspection required by these operating limitations.
https://avsport.org/pwrpoint/matrix.pdf
He is partly correct. The LSRI doesn't any maintenance privileges, only inspection privileges. That may have been where he was coming from. You are correct in that there are no special certificates required to maintain or repair an aircraft with an experimental airworthiness certificate. I always said that if I could have taught my dog to work on airplanes, she could have done so on an experimental without any supervision.
I had a friend that called the FAA to put his EAB back into phase 1 after a major rebuild from being flipped in the storm at Sun'n Fun several years back. The FAA guy told him you can't work on that. he mentioned that he had the repairman certificate for the airplane and the FAA guy said that is only good for inspection not maintenance. The FAA guy thought an A&P certificate was requited for the repairs and maintenance. The FAA guy got schooled.
yabiah
Post by yabiah »
According to Advisory Circular 65-32A, Chapter3, 303 b, “a non-certificated person may perform additional maintenance etc”.
So, I think I’m good.
Advisory Circulars are not regulatory. The FAA person's problem is he was siting from CFR 43.3 which says who can perform maintenance, but he forgot to look at CFR 43.1 which shows applicability of part 43. CFR 43.1 says that part does not apply to an ELSA which previously geld a SLSA certificate. That means CFR 43.3 which tells who can work on airplanes does not apply.
jet9919
Post by jet9919 »
Hi Fellow Sting Owners.
I have a 2002 Sting Carbon and are due to check the elevator stabilizer - Service Notification 043012
Inspection of horizontal stabilizer connections.
Can anyone advise good advise on this procedure and the approx time it took to carry out.
Thank you
